Home › Forums › Products › Rackmount › SP/DIF questions › Reply To: SP/DIF questions
May 8, 2008 at 5:59 am
#117470
Yannis
S/Pdif is simply a consumer protocol generally not recommended for pro_audio high sampling rates. AES-EBU is the way to go for 96. But if you really must use 96, then the S/Pdif 3/4 has a better performance in terms of clocking stability.
You can't mix different sampling rates. One clock rate for the whole unit.
best
I
