Reply To: Modfactor issue – FX Loop phasing issue with Trem/Pan
Home Forums Products Stompboxes Modfactor issue – FX Loop phasing issue with Trem/Pan Reply To: Modfactor issue – FX Loop phasing issue with Trem/Pan
#117477
asaunders
I may be wrong and haven't tried this myself, but is this an unavoidable problem of sample latency? the signal going into the parallel effects loop ends up being delayed by a very small but necessary sample buffer as it goes through the A/D and then D/A converters in the ModFactor. Running it in series will keep the entire chain delayed by the same amount of time.
