Home › Forums › Products › Stompboxes › Midi Clock Problem with Timefactor->Modfactor › Reply To: Midi Clock Problem with Timefactor->Modfactor
November 30, 2010 at 10:35 pm
#121067
Hi there,
thanks for confirming. I was almost sure this wasn't normal. I'll wait for your answer. Glad you are working on the new software-version anyway. Actually, I'm a little bit surprised that I'm the first to stumble upon this …
In the meantime, I have connected the MF as master and the TF as slave. Everything seems to be working fine this way. It's not what I wanted originally, but it will work until the problem is solved.
UJR
