Home Forums Products Stompboxes Timefactor Overload? Reply To: Timefactor Overload?
#122628
    An Eclipse has a much higher potential output level than a TF, in order to give it a lot of headroom in normal use.
    You can choose how hard you drive the Eclipse, and also set its output gain, as you have already discovered. So, you should be able to set it up for best performance without too much difficulty.
