Home Forums Products Rackmount Eclipse – whammy – Detunes mode how? Reply To: Eclipse – whammy – Detunes mode how?
#122691
    Here's a start (from the manual; I don't own an Eclipse yet):
    Select one of the shifter algorithms ("Dual Wammy").
    Use the Master parameters.
    Set the Heel parameter to 0 cents.
    For a Shallow emulation, set the Toe parameter to – 4 cents.
    For a Deep emulation, set the Toe parameter to – 30 cents.
    Delay to minimum.
    LowNote to match the input instrument.
    XFade to minimum.
