Home › Forums › Products › Stompboxes › Bypassing by CC- works but doesn’t bypass in patch change › Reply To: Bypassing by CC- works but doesn’t bypass in patch change
November 29, 2011 at 9:13 pm
#122874
How about having a "blank" preset on the TimeFactor that does not pass any Wet signal.
So for all banks on the GCP you do not want the TimeFactor, you just call up the blank preset.
I used to use a TimeFactor in a rack with a GCP, but I used to just kill the FXLoop with midi on the modeller I am using…. Is that an option?
