Home Forums Products Stompboxes Bypassing by CC- works but doesn’t bypass in patch change Reply To: Bypassing by CC- works but doesn’t bypass in patch change
#122875
J.Paul
    badmelonfarmer:
    How about having a "blank" preset on the TimeFactor that does not pass any Wet signal.
    So for all banks on the GCP you do not want the TimeFactor, you just call up the blank preset.
    I used to use a TimeFactor in a rack with a GCP, but I used to just kill the FXLoop with midi on the modeller I am using…. Is that an option?
    good suggestions, thank you
    ~Yes I have considered using a blank program as a last resort
    ~ I would still like the option to pull it in and out of a GCP preset/ patch but by using a blank Time Factor patch it's just a buffer and no effect is present
    ~The "kill FX loop" is the best way to do it but is not an option. I THINK that method needs a mixer which I am not using right now (If I understand what you're saying).
