Home Forums Products Stompboxes space- freeze mode in shimmer Reply To: space- freeze mode in shimmer
#124572
rabiddiabetic13
    I asked this same questions a few months back,  Got no response
    "When I use pitch freeze the pitched shifted sounds fade away, basically cuts right out when I use hot-switch to activate.  Is this the way it should work, I was under the impression I would hear the two shifted pitches in a hold pattern and could play over it with reverb."
    Thanks,
    Anthony
