Home › Forums › Products › Stompboxes › Midi Clock SYnc Not Working › Reply To: Midi Clock SYnc Not Working
September 27, 2013 at 5:02 pm
#124860
Assuming that everything is connect properly and that you set MIDI Transmit to "THRU" and the Midi channel is the same, and that you have tap tempo enabled on your presets, I would say that the Pedal isn't getting midi Clock data from you're Alesis.
