Home › Forums › Products › Stompboxes › MIDI CC over USB › Reply To: MIDI CC over USB
December 8, 2013 at 4:58 pm
#125083
Quote:
what program can I run to use the CC transmitted from Space to my computer back to my midi controller?
I'm not sure whether this will work with your particular setup, but I use a 'postcardware' program called Bome's SendSX; sometimes as a routing utility. There's a MIDI Thru setting in Options to connect an incoming MIDI Input to a listed MIDI Output.
Another 'classic' toolkit is MIDIOx (32-bit, though). If you're going through some type of DAW application, there may also be some MIDI routing applications available there, too.
