Home Forums Products Stompboxes Pitchfactor freezing issue Reply To: Pitchfactor freezing issue
#126237
    This is not good. Sorry. My first thought would be that you were using a different power supply, but this is not the case.
    The first thing to try is re-initializing the unit. See UM for info.
    If this fails, it is probably a hardware problem. So you will need to contact support@eventide.com
