Home › Forums › Products › Stompboxes › Lag when controlling expression knob via midi › Reply To: Lag when controlling expression knob via midi
August 17, 2014 at 12:43 am
#126520
Hey Brock, thanks for replying! Yes, I used to use Midi-Ox on an XP machine. I will have to check out the others you mentioned.
FAMC has said that the next firmware an editor should address the issue with the factor pedals,Space and the H9. They have added a new option "Force Zipper" .
"It will do exactly what it sounds like- force the pedal to send all
intermediate values between last value and the current. This shouldn't
be used in normal operation, but perhaps will help for those having 'H9'
type issues."
I will report back once to becomes available and I've given in a try.
