Home › Forums › Products › Rackmount › Global Wet/Dry Mix Ratio › Reply To: Global Wet/Dry Mix Ratio
March 28, 2008 at 8:16 pm
#128368
i have my wet/dry mix set to 100% wet and control the mix within each preset. setting the individual mix levels on each block means i can run some delays at about 35% wet for a natural sounding effect, but i can also run some at 100% for special fx. also good for filters etc where you might want to process the whole signal. it's a bit more work in terms of setting up each preset, but it does give you a bit more flexibility.
sim
