Home Forums Products Rackmount Does anyone use Reverb 2016 for guitar live – need feedback Reply To: Does anyone use Reverb 2016 for guitar live – need feedback
#128395
 Yep!
The POSITION parameter is a simple magic delay trick. Available on H3000 Dense Room, on some DSP/Orville/H_series reverbs and on Eclipse Dense Room8 and 16 algorithms.
2 delays feed 2 diffusors which feed the reverb. The delays and fiffusors are also sent to the outputs, in parallel to the reverb. By raising/lowering the parallel delay path level you get the impression of hearing your position in the reverberant space as being more upfront or in the rear. Great to simulate walls around the sound source or the distance in the verb field. Nice on screaming solos! The tone gets very thick in upfront position.
best
