Home › Forums › Products › Stompboxes › expression pedal with tap tempo › Reply To: expression pedal with tap tempo
April 12, 2008 at 10:49 pm
#128481
If you set the Expression Pedal to control just Feedback, then that is all it will control. You can then use an Aux Sw to tap in the tempo and it will stay the same, heel up or down.
