Home Forums Products Rackmount Change battery in Eclipse Reply To: Change battery in Eclipse
#130191
    To quote Panasonic-san: coin type lithium batteries are available in two types: poly-carbonmonofluoride lithium batteries (BR series) for uses that require extended reliability
    and safety, and manganese dioxide lithium batteries (CR series) for uses that require high voltage and strong load pulse characteristics.
    So essentially either can be used. CR types probably have slightly higher capacity and better current supply characteristics, so may last longer. But not by much.
