Home Forums Products Stompboxes Midi control of MF from TF Reply To: Midi control of MF from TF
#133255
badmelonfarmer
    Hi Tim … Martin here 🙂
    you still, need the Merge, even if you set the TF Clock via MIDI CC and output it From the TF to MF…you would loose the PC changes from the GCP to the MF or vice versa…. back to the same problem.
    Cheers
    Martin
