Home Forums Products Stompboxes Space Aux pedal problem Reply To: Space Aux pedal problem
#136727
    Alternatively, it may be the setup on the Space. Connect one switch to it, and use the LEARN feature to see if you can get any life from it.
    Another way to test the switch is to connect it to the pedal input (tip and sleeve) – pressing it would be the same as pedal down.
