Home Forums Products Stompboxes Bank and midi controller + levels problem Reply To: Bank and midi controller + levels problem
#138108
gkellum
    LEONARDPAUL:
    But when I use a simple Midi controler such a Midi Moose from Tech21, the problem is the same with the Space but not with the 3 others (Time, Mod and Pitch).
    Do you have the latest v5 software release of Space installed or are you using the older v3.5 release? As I mentioned earlier in the thread, I'm pretty sure the latest release has a configurable spillover crossfade time. I'd pull out a Space and double check that for you right now, but we just had a blizzard and our office is closed and I don't have a Space with me at home. I could check that for you tomorrow though.
