Home Forums Products Stompboxes H9 global tempo/MIDI problems? Reply To: H9 global tempo/MIDI problems?
#138598
    Does the H9 tempo actually change ? The CC may expect to see a momentary switch, meaning it goes high (above 64) then low (below 64) to be recognized. If this is the issue, you think you are tapping in a new tempo, but it is not changing.
