Home Forums Products Stompboxes Using Eventide pedals with MFC-101 midi controller Reply To: Using Eventide pedals with MFC-101 midi controller
#140251
trancegodz
Support sent me this message: “On our stompboxes you need to go into the System Menu, then select MIDI and RCV CTL. Turn the encoder until you see TOG on the left side of the display. Hit the right footswitch and this will allow you to turn the encoder and set the MIDI CC number that you will send to the unit to toggle it between bypass and active.”
I tried it and I was able to get an IA on the MFC-101 to turn on and off a preset on the Eventide, but I have to push the IA button twice to turn the Eventide on and twice to turn it off. Is there any way to make it so you only have to push the IA once to turn it on and once to turn it on?
