Home › Forums › Products › Stompboxes › Modfactor with bluetooth › Reply To: Modfactor with bluetooth
January 7, 2016 at 2:52 pm
#142074
Trendin wrote:
I want to connect a usb to blueooth connector to modfactor so it could have bluetooth capabilties. Is this possible?
The ModFactor has a USB slave jack. Bluetooth USB dongles need a USB master jack. So, as you're describing it, this won't work.
For this to work, you would need some sort of wireless MIDI device that connects to the ModFactor directly over MIDI and connects to your computer wirelessly in some fashion. If you do some online research, you might be able to find something that does this. The solutions I know of are all geared to use with iOS devices; I don't know of anything offhand that will meet your needs.
