Reply To: Midi Foot Controller H8000FW
Home Forums Products Rackmount Midi Foot Controller H8000FW Reply To: Midi Foot Controller H8000FW
#142595
Rolandmangrove
I use a fcb 1010 with uno chip. This works very good. I use it in stompbox mode controlling parameters (cc) and program switching (pc). Programming the fcb 1010 is very simple if you use ripwerx software. If you want to use the fcb 1010 switches for bypass dsp A or B you have to get the switch in toggle mode. You can do this by setting the first value to 127, the second to 1 but uncheck the box. It took me a while to figure this out using the H8000/fcb 1010 uno combo. The fcb 1010 is solid as a rock. I have used mine for morer than 10 years live on stage and it stills works as a charm! I believe you get a lot for the money you pay for.
