Home › Forums › Products › Stompboxes › Space reverb stomp box – volume problem › Reply To: Space reverb stomp box – volume problem
April 16, 2016 at 4:31 am
#143190
Are you using the Out Lvl in Amp or Line setting?
After recently updating my Space to 5.2.0(6), the effected signal always acts as if the Out Lvl was set to Amp (dry signal uses the actual setting). This would also explain why the active button doesn’t seem to do anything for some people.
