Home › Forums › Products › Stompboxes › Sending CC with the H9 › Reply To: Sending CC with the H9
May 25, 2016 at 10:30 pm
#143442
dafonk wrote:
What MIDI OUT mode should I use ?
XMT, THRU, MERGE ?
Normally you would use XMT, unless you also want to pass MIDI through the H9, when you would use MERGE. Don't use THRU, as this will prevent the H9 from sending your AUX switch CCs.
