Home Forums Products Stompboxes PowerFactor2 Question Reply To: PowerFactor2 Question
#143872
Dario
    Hi, thanks for your reply,
    On the user guide of the Infinity Looper is written that it requires 300 mA (negative tip) at 18 V,  why did you said that it draws 70 mA?  Maybe it’s not relevant?
    I ask it, because on the user guide of the Pigtronix it says that ” Using wrong power supply is likely to result in a damaged pedal”, so I want to be sure
    Another question:   which outlet will I use with my H9?
