Home Forums Products Stompboxes External TAP TEMPO Reply To: External TAP TEMPO
#144518
markosassuncao
    gkellum wrote:
    Well, to configure this in H9 Control, click on the Pedal button in H9 Control’s bottom menubar, go to General Settings, and then to ‘Use Expression Pedal, Aux Switch, or Both, and set that to ‘Aux Switch’.  Then press the Pedal button again to return to the top level menu and go to Aux Switch Mappings.  You’ll see there the current Aux Switch mappings.  You’ll want to disable one of the mappings to free up one of the aux switches.  Then you’ll want to press the ‘Tap Tempo’ button, and you can select there which switch you want to have trigger ‘Tap Tempo’.
    Hi dude,
    This way didnt work.
    I’ve sent a pdf with photos os step by step.
    I need help
    Thank you
