Home › Forums › Products › Stompboxes › H9 Encoder knob keeps falling off › Reply To: H9 Encoder knob keeps falling off
October 26, 2016 at 2:37 pm
#144738
Well, here are the instructions that we send to people who are trying to reseat their encoder:
If you look at the encoder, there is a cap on top, the inner most circle, which you should be able to gently pop out with a pick or similar type of tool.
You should now see the nut. Gently loosen the nut
Lift the encoder knob at the sides and make the nut level with the top of the shaft.
Then tighten the nut without the letting the sides drop down.
It’s important that the nut is level with the top of the shaft. That will allow it to have the push function and to make the popping noise.
If you think the encoder or cap is broken in some way, you can contact support@eventide.com if you'd like to buy a new encoder and cap.
