Home Forums Products Stompboxes Kill Dry-mix knob function and Output Reply To: Kill Dry-mix knob function and Output
#144921
cscotto
    I just want to know with kill dry on, how does the function of the knobs change. You answered one: the mix knob becomes an instensity function. I am assuming the output knob simply increases the level of the wet signal. If I am running the box in a parallel effects loop, then increasing the level of the output would add more effect to the dry signal.
    In the end, but knobs would do the same thing: increase the intensity of the effect, but one would do it without increase the output level.
