Home Forums Products Rackmount 1745M outputs question Reply To: 1745M outputs question
#146732
rfactor
    The five XLR connectors represent the outputs of five separate, adjustable delay or pitch change cards.  Whatever you connect to the input is delayed by a variable amount by each card and then goes to the associated XLR output.  So, the XLRs are not wired "together."  The connectors that are not associated with a mainframe card will have no signal; the others will.
