Home Forums Products Stompboxes Use external MIDI device to scroll through H9 presets and auto-load? Reply To: Use external MIDI device to scroll through H9 presets and auto-load?
#147222
wilkinsi
    camn wrote:
    yes of course.
    You decide which CC you want. You set it up in the H9 control
    You can also use PC to call certain presets directly. Also setup in H9 control.
    The helix should do all that easily… be warned though.. there have been some troubles using the helix for the ‘performance switch’. Use an aux switch for that of you can/care/want
    Please can you give me a working example? I assume you mean the MIDI side of Helix is bugged and that I’m better off using the AUX jack instead?
