Reply To: Adding a Swell/Volume pedal function
Home Forums Products Stompboxes Adding a Swell/Volume pedal function Reply To: Adding a Swell/Volume pedal function
#147778
da7thson wrote:
For me a good enough solution would be a Volume algo, that you program as a preset which basically controls the volume via an expression pedal. I can recall that patch via midi if i need a volume pedal. Job done.  i would need to pre / post feature on the patch then i can have it at the end of the chain or at the start.
simples
Something like this should work for you:
With my Roland EV-5’s, most of the swell control is in the upper 2/3rds of the pedal throw.  It’s possible to snap between two fixed volume levels, with a ‘parked wah’ position (toggling the left Active / Bypass footswitch).
