Home Forums Products Stompboxes H9 Pitchfuzz lag when switching via midi Reply To: H9 Pitchfuzz lag when switching via midi
#148059
    mjunker wrote:
    … the effect kind of seems to fade in when switching instead of a “hard” effect switch … What I noticed is that the effect drops out completely and then there’s kind of like a volume swell where the fuzz effect comes in …  Any ideas what could be the problem?
    I’ll take a stab at this one.  Assuming that you’re switching between supplied Factory Presets, there are large variations in Output Level, from preset to preset.  Around 18-20 dB (I believe), in some cases.
    PitchFuzz does not have the separate Compressor / Sustainer controls of the Sculpt / CrushStation algorithms, but it is from the same family lineage.  Program-dependent compression:
    H9 Sculpt / CrushStation Info wrote:
    … specially designed to vary the numerous parameters of a typical compressor such as the ratio, attack, release, and the makeup gain to keep the overall loudness consistent.
    My suggestion:
    • Figure out the exact Output Level that works best for your own setup.
    • Use H9 Control’s input and output meters (+ H9 Overload LED) for a strong, clean average signal thru.
    • Dial in that new Output Level in a few Factory Presets.
    • Rename & save them as User Presets.
    • Try switching between the new User Presets.
    You may still have to adjust the individual User Presets’ Output Levels a few dB, either way.  But that should give you a good idea of the “auto-level” compression action at various FUZZ parameter values.
