Home Forums Products Stompboxes Pitchflex alg is glitchy Reply To: Pitchflex alg is glitchy
#148213
wedelich
    boynigel wrote:
    .0
    What's strange is the fact that it used to work perfectly a couple of years ago.  i stopped using pitchflex for a while and i'm sure i've done an update since the last time i used it.  i wonder if there was something in one of the update(s) that is causing this problem.  the only thing that has changed in my H9 setup is that i am now using a Tech21 MIDI Mouse with it to scroll the presets.  don't see how this could be a factor though.
    It should be smooth, we'll double check the latest build.  Does it smooth out w/o the MIDI Mouse connected?  I wouldn't think that would make difference either, unless for some reason the MIDI Mouse was bombarding it with MIDI CCs or something (I doubt it).  Also, what kind of expression pedal are you using?
