Home Forums Products Rackmount H9000 VSIG Support – FAQ says YES Reply To: H9000 VSIG Support – FAQ says YES
#151370
jbamberg
    macgee wrote:
    In my case I have to put in IP manually. On mac side it's automatic though. And in VSIG there's no option to specify IP of box.
    There should be a field in the "Send to H9000" dialog where you can enter an IP address.  The dialog lists the H9000s that could be found on your network using bonjour, which may not work from a VM because of network address translation.  (I think different VM hypervisors arrange the networking differently, and some let you choose a NAT or bridging configuration).
    If you are able to connect from emote running on your Windows VM by entering the IP address, Vsig should also be able to connect in a similar way.
    I'll double check tomorrow that the version we released as beta has this IP address field.
