Home › Forums › Products › Vsig and Preset Development › VSIG-H9000-Send to H9000 greyed › Reply To: VSIG-H9000-Send to H9000 greyed
May 17, 2019 at 4:21 am
#151908
Do you have both the H9000 and your VMware/PC on the same network? If the two of those are on the same network, this should work with even just a VERY simple VSIG file. Do you see the serial number of your H9000 listed when you do the Transfer to H9000 command? You should see it listed in that window. You would highlight your H9K (typically it shows the H9000’s serial number). Once you highlight the H9000, you should be able to transfer.
You do not use MIDI at all when transferring to the H9K. It is all done over the network.
