Home › Forums › Products › Plug-Ins › H3000 factory won’t validate in Logic 9 › Reply To: H3000 factory won’t validate in Logic 9
May 27, 2019 at 10:21 am
#151965
This is the message I get when I try to run it through the AU manager:
validating Audio Unit H3000 Factory by Eventide:
AU Validation Tool
Version: 1.6.1a1
Copyright 2003-2007, Apple, Inc. All Rights Reserved.
Specify -h (-help) for command options
VALIDATING AUDIO UNIT: ‘aumf’ – ‘Fact’ – ‘TIDE’
Manufacturer String: Eventide
AudioUnit name: H3000 Factory
Component Version: 3.3.4 (0x30304)
* * PASS
TESTING OPEN TIMES:
COLD:
2019-05-27 11:15:20.633 auvaltool[281:a07] Error loading /Library/Audio/Plug-Ins/Components/H3000 Factory.component/Contents/MacOS/H3000 Factory: dlopen(/Library/Audio/Plug-Ins/Components/H3000 Factory.component/Contents/MacOS/H3000 Factory, 262): Library not loaded: /usr/lib/libc++.1.dylib
Referenced from: /Library/Audio/Plug-Ins/Components/H3000 Factory.component/Contents/MacOS/H3000 Factory
Reason: image not found
FATAL ERROR: OpenAComponent: result: -50,0xFFFFFFCE
validation result: couldn’t be opened
updating properties of AU H3000 Factory by Eventide…FAILED!
FAILED!
