Reply To: Beta Tester Presets
#153564
patodruida
Next preset is “Trees”. This one is also a very wet patch with heavy chorus and detuning. I was thinking of trees in the middle of a rainstorm. This one is also meant to be used with an overdriven sound but is more chord-friendly. Playing harder will reduce modulation a bit per the envelope mix setting. Exp pedal can rein in the chorus mix and depth OR it can make it go even wider and wilder. I recommend trying the most extreme settings with feedback. To me it’s almost intoxicating.
