Home Forums Products Rackmount H9000 users: what is your use/workflow????? Reply To: H9000 users: what is your use/workflow?????
#154206
joeydego
    macgee wrote:
    joeydego wrote:
    Curious what the typical use and workflow looks like for H9000 users. I’m currently using “only” 16 channels, 8 via ADAT and 8 audio. Using this in a modest home recording setup. Would like to hear how some of the user base connects, and pics if you have!
    i saw your post in another thread using UAD x8
    that’s my exact config using UAD +audio & adat and then there’s the 16 DAW channels to use as well if needed
    UAD Engl Savage is a pretty good Amp Sim but I’m adding a Strymon Iridium to use for Amps & Speaker Sim instead
    Apollo is great for integrating the H9000, Synths & other gear – with a patchbay of course
    Question for ya. I’m assuming you’re connected ADAT and analog I/O like I am. Do you direct monitor when tracking and are you using cue channels in console to get eventide fx? Also, how are you routed in your DAW? I have a Townsend mic plugged into XLR 3 and 4. I can’t seem to NOT hit the identical eventide analog channel, even though it’s not bussed or sent to it in the session.
