Home › Forums › Products › Stompboxes › Quadravox hotswitch › Reply To: Quadravox hotswitch
May 7, 2020 at 11:59 pm
#154818
birthofahero wrote:
So I know the hotswitch is a "Learn" function but I'm trying to set a button on my midi controller to change one of the voices from a -4th to -3rd and back. Is this possible?
Yes. You can set the expression pedal (ribbon) mapping for that parameter from -4th to -3rd, and then assign the expression pedal (ribbon) to a CC message. Then you can use your MIDI controller to send that CC message to control this parameter.
