Home Forums Products Stompboxes Connection two H9 via MIDI port with software H9 Control Reply To: Connection two H9 via MIDI port with software H9 Control
#155506
bohan
    LagPhil wrote:
    No, I only want to have 2 H9 connected via MIDI port with H9 Control.
    An H9 with other MIDI devices works fine with the H9 Control app.
    The prolel is only when there are 2 H9s.
    It is not normal.
    You can either use USB to MIDI cables to connect your PC to the MIDI ports on your H9s, or use USB cables to connect your PC to the USB ports on your H9s. Both should work but I recommand you just use USB A to USB mini cables. However, ff you need to use some other MIDI devices with your H9s via MIDI ports simultanuously, neither USB or MIDI connection works for H9 Control. You'll have to use Bluetooth.
    Could you take a photo of your setup and attach it here? I don't get what you are trying to do…
