Home Forums Products Stompboxes H9 no sound Reply To: H9 no sound
#156183
tsternfeld
    It's going to be much easier to diagnose the issue if you remove as much as you can(other than your H9) from your pedalboard chain.  That way, you can eliminate possible other causes of issues.
    The H9 itself should bypass when it isn't powered, so you will get audio through it.
    When you say you get "no sound", do you mean you get no effect, or the dry signal doesn't pass through?
