Home Forums Products Stompboxes Thanks for the free license for the H9 Series Plug-in Bundle! Reply To: Thanks for the free license for the H9 Series Plug-in Bundle!
#156405
joecozzi
    Bodde wrote:
    I run two versions of Cubase on the same computer. On Cubase 7 I can’t see the installed plugins at all. On Cubase 9 they all work. Isn’t the H9 bundle supported by Cubase 7? Is the problem with Cubase or with the plugins?
    Assuming you’re using a Mac, but are you running Cubase 7 in 32-bit mode? That could be the problem, as the H9 Bundle is only compatible with 64-bit systems on Macs.
