Reply To: Newfangled Audio Plugins on HiDPI in Cubase – Moseover not working correctly.
Home Forums Products Plug-Ins Newfangled Audio Plugins on HiDPI in Cubase – Moseover not working correctly. Reply To: Newfangled Audio Plugins on HiDPI in Cubase – Moseover not working correctly.
#157958
honeyhill
Hi Dan,
wow that was a quick reply! 🙂 Thank you. I am using two 2k Monitors, I am on Windows 10 with a NVIDIA GPU and System scaling set to 125% for both monitors. Cubase has a dedicated HiDPI mode in it’s preferences. As soon as this is enabled the mouseover issue happens. I tried scaling the plug-in GUI and also tried disabling OpenGL without any luck. I also have a MacBook Pro with Retina Display, I will check tomorrow if it produces the same issues.
I realized that the mouse cursor is not visible in the Screenshot. If it helps, I am happy to do a quick screen recording, demonstrating what happens in the plug-ins. If you need to know any detailed systems specs, let me know.
Thanks for the great support and Best,
Oliver
