Home › Forums › Products › Stompboxes › Create a preset in H90 with one of the two effects off. › Reply To: Create a preset in H90 with one of the two effects off.
January 1, 2023 at 7:50 pm
#168097
Hi juanplays,
There’s a utility algorithm called Thru. Place that in any of the slots to create a direct through path. If you have your algorithms in series routing, putting this first or second and populating the other position with an algorithm of your choice is like running one algorithm.
