Home › Forums › Products › Stompboxes › H90 – routing options › Reply To: H90 – routing options
January 19, 2023 at 12:49 pm
#168530
No this is not possible. In Dual Mode, Path 1 uses Inputs 1-2 > Outputs 1-2, Path 2 used Inputs 3-4 > Outputs > 3-4. The paths cannot be summed, Dual Mode is intended to create two separate signal paths.
You may be able to accomplish your idea using Insert mode. I/O1-2 is the main path, but you can use input 3 or 4 to insert another signal at different points in the main path using the routing page. The Return Level parameter for the insert will adjust the volume of that signal.
