Home Forums Products Rackmount Possible H9000 SP2016 bug? Reply To: Possible H9000 SP2016 bug?
#169455
joeydego
    Audio gets routed out of my daw either ADAT or analog to the 9000, back in the same way. This occurs both using pipeline and direct IO track routing. There is no other direct monitoring happening. I have other outboard (although no other digital outboard) and do not experience any kind of doubling like this. With all tracks on mute, I hear nothing. This also occurs with pipeline either directly on a track or used as an fx send, with the issue becoming more apparent as send level increases obviously.
    I’ll work on audio examples as well as detailed routing. I’m on PC and have 3 Apollo X8 interfaces. All my eventide is going thru one x8 taking all its analog and digital IO.
