Home Forums Products Stompboxes Mixing link possible use? Reply To: Mixing link possible use?
#179292
    Yes, that should work. I would suggest doing it this way:
    • Amp > Microphone > MixingLink Mic/Line in > MixingLink XLR out > PA
    • MixingLink “To Amp” output > Mono into Stereo time based pedals
    • Stereo pedals output > Stereo/Dual Line Isolator/DI Box > PA
    • Set Mix Mode to “Dry + Mix”
    • Enable Kill Dry on your stereo FX pedals if possible, or set their mix parameters to 100% wet
    Most stereo time based FX processors should work well with a mono in stereo out configuration. There is no need to connect 2 outputs of the MixingLink to the stereo input of these devices.
    Let me know if you have any questions.
