Home › Forums › Products › Stompboxes › Wish list from users for future updates of the H90 › Reply To: Wish list from users for future updates of the H90
Parameter mapping of insert input gain, output gain and mix would be cool.
I’ve been experimenting using my volume/exp pedal to control volume via parameter mapping (as opposed to as a volume pedal before the H90) so that for some programs I can use it for other stuff (wah, pitch, feedback, etc,) and I want to stick both inserts in between the algorithms and then have volume control in between them. In my case, insert 1 is a compressor and I want to control the volume after it, which would be easy with parameter mapping of the output gain so that toe down is 0db and heel down is -60db, if that were possible.
