Home Forums Products Rackmount Eclipse + Midi program changes not working Reply To: Eclipse + Midi program changes not working
#185196
    Hi there,
    Please try the following:
    • Press SETUP twice to go to page 2 of the setup menu.
    • Confirm that the Eclipse MIDI channel is correct (or select OMNI)
    • Press the MIDIMODE soft key and confirm Prog Change is ON
    • This should be enough settings for the Eclipse to receive PC messages and you should see a dialog on the screen when it is loading a new preset
    • You can go to SETUP page 3 > Maps to edit the PC maps, and try Map 1 and reset to default if you still have issues
    See page 29 of the user manual – https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/EclipseUserManual.pdf
